Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Mitsubishi hd 1080 display looks like 3d
Tv looks like 3d try to line up the red and blue but on able to get to advance converging menu don't have original remote control.
  • 23 Answers
Its the motors in the tv that line up the mirrors to get you a picture , can be fixed , but I bought a new one when this happened to me as lamp was due to go
Posted on Nov 07, 2013
5 Suggested Answers
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: Accessing Service menu to fix convergence
How far off are the colors misaligned such that you need to enter the service mode to fox them? If one or more of your colors has taken a dramatic shift in position, especially on any edge, then do not attempt to correct through the menu. If one of your convergence IC's has failed then the colors will not align on the screen. If you try to correct this in the menu, you will only be screwing up all the settings and making the set worse. When the IC is replaced with a new one your colors will still be way off, not because the new IC is not working, but because now the menu settings are too far off. I have been to many houses and spent 45 minutes replacing a burned out convergence IC followed by more than an hour realigning everything the customer messed up.
Posted on Aug 18, 2007
Anonymous
SOURCE: Blurry and convergence doesn't work
I had the same problem. here is how i fixed it: Unplug the set.take off the back panel, the big silver metal heat dispersing element has to come out.its about 5" by 6" the two modules are clamped to the back of this part. I had to slide out the whole board.what has caused the problem is the thermal compound has gotten old and has worn out. clean off the old and buy some new compound at any computer store. i got mine at Best Buy. Its not that hard to do. Don't let all the wires freak you out. unplug all of them. they can only go back in the same place they came from. I could go into a lot of detail on how i did this but that's the just of it.
Posted on Dec 07, 2007
Anonymous
  • 6 Answers
SOURCE: Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Posted on Aug 18, 2008
pls_lakewood
SOURCE: I have a Mitsubishi HD 1080 series 65" set. I just got digital cable and I can get HD channels but it only shows in 480i. When I go to menu on the tv to advance settings if gives the option of 480i an
Connect your component cables to the DTV connections.
Posted on May 01, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: I have a WS-65807 Mitsubishi Big Screen HD TV and
No, you need to replace your convergence ICs STK392-570 Call Mats Electronics 1-800-628-1118
Posted on Dec 31, 2009
The red convergance lines in advanced convergance mode is wavy and not converging but everything else is.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
There is a line right in the middle of the tv going vertically.. the left side is fine but the right side is like 3d tv.. why is that.. Model # WD-62628--- S# 117086... Mitsubishi
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
May 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The picture arced and looks 3D. Plus the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi WT-4211.The picture went to a 3D effect with a red outline.Is this a covergence problem?If so is there a repair kit?
Yes - there is a repair kit. Goto www.TvRepairKits.com
  • Screen looks 3D
Jan 14, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Convergance the green is all over the place!!
  • Screen looks 3D
Jan 07, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Ther is a red line on the left side of the tv the blue an green is alright but it looks like it is in 3D i have tried to line the conrv- but still nothing the red is shifted 2 inchs to the right
  • Screen looks 3D
Jan 04, 2010 | Mitsubishi WS-48515 48" Rear Projection...
CAN NOT FIX CONVERANCE RED & BLUE ON MY MITSUBISH HD 1080 SERIAL ws-55311 NEED A MANUAL ALSO
This is a common problem. Its called a convergence failure.
Symptoms:
Dec 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Have colored shadows around everything on my Mitsubishi HDTV 1080
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Display
OPTION MENU "MENU 1270" SERVICE MENU "MENU 1257" CONVERGENCE MENU "MENU 1259, 4 FINE, 5 COARSE, 6 MISC
Sep 15, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
