Rca tv # L42FHD37E. I need the wire harness that goes from the power supply board to the inverter board. A coil shorted on the power board and melted some wires. I replaced the power board. I can't find replacement wires or cable harness kits for this model.
SOURCE: Need a power supply for RCA L37wd12
This power supply might not be manufactured anymore or the only place to find it is by calling RCA but that is a pricey board. You can also check this website and ask them if they have one. It appears like they do not have stock but you can call them just in case they have not updated the site.
I can also help you in repairing the defective power supply if you still have it. Write to [email protected] if you need further assistance.
SOURCE: RCA L32WD22 TV with a bad power supply
The solution to your problem is to not buy this junk from Wal_mart in the first place. You won't find any replacement P.S. anywhere. This is consumer fraud from RCA, file a consumer fraud suit against RCA. The law says the manufacture must supply parts for at least 5 years from date of sale. Dan@DBS
SOURCE: RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
SOURCE: tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
