Turns on date & time on screen will not let me set it & pressing all buttons but not doing nothing
SOURCE: Fiji Finepix S5500
solved my own problem, but for the benefit of others.
the camera is held together via about four/five small phillips screws. these need to be removed. the back of the camera will come away from the body. Make sure you don't pull too hard as there is a small connecting ribbon between the camera and the rear circuit board attached to the back. This ribbon is held in place at either end by small brown/tan coloured clips that hinge up to release the ribbon and down to clamp the ribbon to the connections. Try removing the ribbon ends and replacing it. If you are careful you can do this with batteries in place. Make sure you have your card in place, it won't work otherwise. I just realigned the ribbon and the camera works wonderfully. Might help with other errors. also a small ribbon attached to the multi function button, may have the same result for other problems. good Luck.
SOURCE: camera turns on but it does nothing.
The ribbon cable for the buttons has either come out of its socket because it was not locked down (does happen) or it is broken and will need to be replaced. Fuji will not send out spare parts but will fix it for a price. Last quote I got from fuji to fix the keypad ribbon on an F470 was £80. check ebay for donor camera
SOURCE: my camera keeps telling me date and time not set though I have se
no I have not solved problem kepy trying ro subsbribebut my debit card was not shown there was no maestro card shown
SOURCE: says date/time not set but wont let me set the time or date!
Broken keypad ribbon. It's because the keypad ribbon is folded over twice and the creases split over time. have a look at my tips page for this problem. It won't help you much I know and the only solution is a replacement membrane.
SOURCE: I'm having the same problem
This is a case of the main board within the camera having errors. The processor that controls the functions of the camera is not booting up to give the parameters needed for the drive and execution. You can reset the camera by removing the battery- make sure this is full charged- removing the memory card. Now depress the ,menu and shoot buttons to drain off all residual voltages on the processor. Check the memory card on you PC, open files and transfer all files toa marked folder. Now FORMAT the card. Replace the battery , card and check. If the camera hangs up while power the camera keeping the lens hood on your palm tap the camera so as to reset any jammed mechanism. If not the camera must be checked for consensus with a service center.
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
