Have you removed the shipping bolts that hold the drum in place while it was moved. If not, remove them and the vibration will disappear. If you did not install the shipping bolts when you moved it, there is a reasonable chance you have damaged the machine and will need to have it repaired.
the shipping bolts should always be in place when transporting the machine but i can also depend on how far you are traveling and the road conditions.you can order them from a local parts store
If you are moving the washer for a long distance move, it is recommended that the shipping bolts be reinstalled to help prevent damage to the drum and suspension mechanism. This would be especially important if you're using a professional moving company, as they won't be able to move/load/unload it without problems.
If the move is relatively short and won't experience alot of aggressive movement, you can likely move the washer without chance of damage - provided you are careful and don't bounce the washer around.
Here's the info from the Maytag website, regarding moving front loading appliances:
If you are moving to a new home and plan to take your front-load washer and dryer pair with you, please call
800-688-9900, and speak to a fabric care expert. Our expert can recommend a Maytag-authorized servicer who will reinstall new shipping bolts to your washer.
New shipping bolts must be reinstalled to avoid internal suspension and structural damage to your washer during transport.
OK, so get your model number handy and give them a call, (you're missing some digits/alphas) you can get an online copy of your owner's manual that will show you the part numbers for the shipping bolts, if you've misplaced them, or give a call to the toll free number for Maytag, and they'll provide you with the part numbers needed so you can order them yourself and likely save some money versus having a service tech some out and do it for you/
1 (800) 344-1274 U.S. 1 (800) 688-2002 Canada
Hope you find this very helpful and best regards!
Just looked at mine (we had to order them before the military would move ours). They are two different sizes, have a long plastic washer (lengthwise), and are - believe it or not - like a lag bolt on the end! A hybrid mess meant to force us to order them, if you ask me. Not sure you should try rigging it, best if you order them, you'll see what I mean when you get them. Sorry, we were in the same boat too. Wish I never bought this LG, but that's for another post.
In order to move one of the new front loading machines, the shipping bolts/supports that originally came installed with the unit must be in place to prevent damage. At this point you can attempt to make repairs yourself or, if under warranty, calling a authorized repair center for repairs. The warranty will not cover damage due to moving the machine without the bolts/supports, however having a authorized service center make the repairs will keep the remaining warranty intact.
A total of four shipping bolts need to be installed: two longer ones on the bottom and two shorter ones on the top. Each shipping bolt consists of a metal screw inside a plastic cylinder which fits between the washer suspension and the back of the washer cabinet. The metal screw pulls the washer suspension against the plastic cylinder which, in turn, is pulled against the rear cabinet, thereby securing the suspension against the back of the cabinet. The Whirlpool part number is 285955. These bolts can be ordered from various suppliers for $20 - $30. To install these bolts, you will need a 13 mm wrench and a flashlight so you can see where the bolts screw into on the washer suspension.
The procedure is as follows: 1. On the back of the washer, remove the 4 plastic covers over the oblong shipping bolt holes. Carefully pack these covers with the water and drain hoses as they will be needed when the washer is re-installed in its new location. 2. Using the flashlight as a visual aid, look inside the oblong holes and identify the area on the washer suspension into which the shipping bolts screw. It is a white plastic part that is not directly behind the the shipping bolt holes, but is slightly above that level. 3.Look at the shipping bolts. The bolts described above (Part number 285955) have a a plastic arm at one end . This arm must be sawed-off for installation on older machines. You will have to determine whether or not the arm needs to be removed. 4. Starting with the bottom two holes, carefully slide a shipping bolt through the hole toward the front of the machine. Angle the bolt upward toward the screw mating hole, and carefully guide the bolt into the hole. Use the 13 mm wrench to engage the bolt into the mating hole. 5. Make sure that the plastic end of the bolt is closely seated against the back of the washer cabinet. Using the 13 mm wrench, screw in the lower two bolts, but do not tighten at this time. 6. Repeat steps 4 and 5 for the upper two shipping bolts. 7. After the plastic part of all 4 bolts has been firmly seated against the back of the washer cabinet, carefully tighten all 4 bolts. 8. Go to the front of the washer and push on the drum. The drum will rotate but it should not rock. If that is the case, then you are done.
