SOURCE: wireless controller up and down moves in opposite
To fix your controller , go to the "Options" menu in C.O.D. and select "Controller," then click on "Normal". It should be set on "Invert" right now. You want to change it to "Normal"
SOURCE: Xbox controller not working only has two lights on game pad
There should be a sync button right on the top of the back of the Xbox 360 controller. While the system is on. Power on the controller. Hold down the sync button on the controller, and then press and hold the sync button on the Xbox 360 console. Wait for a few seconds until the Xbox 360 controller lights stop blinking. Then test out the controller. Any comments of questions, post them by clicking on the add more details link inside of this question that you've asked.
SOURCE: Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Cheers
Karl
