Kitchen Ranges Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set clock and program timer for auto brew. thanks.
I have a dcc 1000 cuisinart coffee maker that i got used from a friend. i do not know how to set the clock and them programm for auto brew. thanks.
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on May 01, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
599475
Points
5720
This link will take you to the manual for your coffee maker:
http://www.cuisinart.com/share/man/23_man.pdf
Cuisinar coffee maker unreliable brewing?
Hi Patti. Set it to automatic. That way when you turn it on to use it, it will be on and should work fine. Joe
12helpful
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Hello i have a cuisinart dcc-2000 i can't seem to find the user guide i need to know how to keep the coffee maker on it usually turns off in about an hour after coffee is brewed. leticia
The user guide is available from www.cuisinart.com
Turn the coffeemaker to Auto-Off - by default, it will say "2:00," but it may have been manually changed to "1:00"
Hold in the hour button until the clock starts flashing, and then advance the hour button until the display says "4:00" (remember: this is on the auto-off setting only).
Now, whenever auto-off is activated, it will stay on for 4 hours.
-Tha Mp3 Doctor
Cuisinart DCC-1000 shuts off on it's own
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
7helpful
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
2helpful
3answers
My DCC-1200 won't turn on
I called Cuisinart. There is no way to fix it. If your coffee maker is still under warranty (3 years) they will replace it. Otherwise, its next stop is the landfill.
17helpful
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
