Question about RIM BlackBerry 7100G Smartphone
Device error 322 - RIM BlackBerry 7100G Smartphone
Error sc322 ricoh 4100
SC 322 1st beam laser sync error: Defective engine board
SC 322 1st beam laser sync error: Defective laser sync
SC 322 1st beam laser sync error: Defective LD unit
Sorry, -Carl
Aug 25, 2012 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Check printer(##322) error in canon fax l220
Error # 322 is a Fuser not heating error. This usually means the fuser is bad or requires a fuser module. This is not something you can test without servicing the unit, so it would need to go to Canon or an Authorized Service Center for repair.
Jul 09, 2011 | Refrigerators
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
When I send a fax, I get error code 322. I can't receive faxes either.
The error depends on the fax model that you are using. Error 322 on Canon Fax and other machine may significate that the Fuser is not heating (Usually Bad Fuser Module).
A different thing is Comm error 322 on computer, that means that there is no communication, and can be caused by bad phone cable, software problems and hardware problems.
In that case ensure that you are using a fax cable with two poles. If the problem started recently do a system restore to a date before the problem started.
If you get the 322 on display, even when computer is not connected, you usually need to replace the fuser unit.
Regards.
Mar 06, 2010 | Computers & Internet
Error coad 322 is showing. what i do now?
ERROR 322 is Laser synchronization error
Detected LD error signal for
continuous 1.5 seconds while
polygon mirror motor was
running at constant speed.
Possible Cause • Synchronization detection mirror
defective
• LD unit defective
• FCU defective
• LD harness damaged
• THM not in place
Jan 08, 2010 | Ricoh Aficio 1013F Copier
##322 - error code. Alarm light will not shut
##322 is the fuser unit not warming up!Can be replaced and fixed!
Dec 10, 2009 | Canon Office Equipment & Supplies
It has an error code 322.I took out the drum unit but upon returning it gave me the error code
sc-322 is a code of laser synchronization error.just open the laser unit and clean all the mirrors and lenses carefully with a soft cotton cloth or j cloth.and also clean the polygun motor.this
Dec 07, 2009 | Ricoh Aficio 1013 Copier
Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Apr 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
Dec 05, 2007 | Office Equipment & Supplies
RIM BlackBerry 7100G Smartphone Logo
Top RIM Computers & Internet Experts
Artur Heise
Sheldon Dedek
matt
matt
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
