Unable to slide tray, are their supposed to be service ports?low side pressure schould be?
Some of this TRUE don't have service valves, but you can put a tapping valve (A1) in the appendix (small piece of pipe comming out of the compresor and seal on the other end).To check the pressure you need to know what type of refrigerant is in the system .If is 134a the low side should be about 24psi and the high around 160 it could vary depends how hot is inside the place and the fridge but not much more than 200.If you working with R22 pressures be around 60 low and 250 high side.
