Need a jumper wire to connect thermal fuse to heating element
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
SOURCE: No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
SOURCE: Kenmore Dryer won't heat
ok you moving in right direction but you jumped a step,,you already checked the thermal cut offf and the operating thermostat,,those where the two on the side of the heater housing,,you should have checked the thermal fuse and the thermistor,,they are on top of the blower wheel housing tuck a lttle to the left,,since you seem that you know what your doing just jump them out starting with the thermal fuse,,,keep me posted on the job
SOURCE: I own an electric Kenmore Dryer model #
did you check the high limit or cut off thermostat part number 3977393 located on the top of heater box,why did you change all those parts,do you have a meter if not get one,it would be cheaper to buy a meter instead of paying for parts that you didn't need,hope this helps
SOURCE: Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
