Sharp ar-5620sl error f2 - Office Equipment & Supplies
David Gust
    Sergeant:
  • 181 Answers
According to the service manual, here are the possible answers for your error code F2
https://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Posted on Sep 24, 2019
5 Related Answers
Anonymous
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
Anonymous
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
MIAN
  • 87 Answers
SOURCE: F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Posted on Dec 18, 2008
san3409jl
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Anonymous
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
Sharp ar-5620sl, how can i do when error code h4 displyed?
you need to reset the error its telling you that your fusing unit is not ok
Jun 01, 2016 | Sharp Office Equipment & Supplies
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
F2 ERROR CODE
Oct 22, 2008 | Sharp AR-C160 Color Copier
121 people viewed this question
Marvin
Marvin
