Question about Xerox Phaser Office Equipment & Supplies
Replace magenta error message xerox phaser 6280
Did not receive a warning to replace magenta soon. Got the message to replace magenta, replaced the toner, and still get the message.
3 Related Answers
Anonymous
  • 141 Answers
SOURCE: Can Xerox Phaser 6280 be refilled by Consumers?
The 6280 uses a specially designed toner called Emulsion Aggregation toner. This is a special type of toner made by Xerox. Sice it is so new and patents exist, I doubt that anyone can legally make the toner, even if they posessed the equipment and the expertis. Refilling with non-EA toner is asking for big trouble.
Posted on Aug 12, 2009
Chad Conrad
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: XEROX Phaser 6250 DP "Install or
In your case the cartridge may be damaged..if you do not have another one ...try to insert another color in its place and see if it is seen proper..and move this one in the others place and see if it does the same ..if does,,than you know that yo need another cartridge...for magenta ..If you know how to do it ..a reset will help and may make it recognizable again .
to reset try to unplug ..and press the power button and plug it again while keeping the power button down for a few seconds..(about 10 to 15 ).
Posted on Oct 25, 2010
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
My Phaser 6280 said to replace magenta cartridge, I did and it still stays to replace cartridge. What do I do?
power cycle the printer, if that doesn't work turn it off completey for a few minutes and power it back up.
Oct 25, 2013 | Xerox Phaser 6280N Color Laser Printer
Xerox Phaser 6280 Y CRUM ERROR
The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Xerox phaser 6180n
Sounds like the memory stick is loose.
If you just received it, that machine has a one year warranty on it.
Call and Xerox will send someone out, or else they will replace it.
Your going to love that printer. WOW what print quality it has.
But your problem most likely was due to shipping and something coming lose.
Call 1-800-835-6100, follow the prompts, they will help make it right.
Jul 11, 2008 | Xerox Phaser 6180N Laser Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
161 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
