Microsoft Excel for PC Logo
Question about Microsoft Excel for PC
Panduit Easymark does not acknowledge Excel 2010
When importing data from Excel 2010 spreadsheet to Panduit Easy Mark a message appears saying "you must install Excel"
5 Related Answers
Anonymous
SOURCE: Sorting Imported sql data
Are you sure you imported the data or did you create a link to sql. If it is a link then it will not allow you to work with a subset of the data because it would effect the data on the sql database.
Posted on Apr 13, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Posted on Jun 10, 2008
Jim
  • 62 Answers
SOURCE: Excel 2000 Issue???
.Let's start with this for more info:
Is the URL icon there but blank? (Maybe an X in the middle of the box?) If it's there, do the following:
Right-click on the URL
2. Select Hyperlink from the menu that appears
3. Is Remove Hyperlink box checked or unchecked?
This is a setting that is machine-specific. Post the answer as a comment and we'll take the next step if necessary
Posted on Apr 02, 2009
Anonymous
SOURCE: Autofilter ceases to work on large Excel 2003 spreadsheet
Sounds like there is a gap between the filter heading and the column data. That's the only time I've seen suggested data missing from the drop-down.
Posted on Jun 18, 2009
Anonymous
SOURCE: I need to be able to scroll Excel 2007 spreadsheets
hold your ctrl key & then scroll
it works
Posted on Aug 25, 2009
4helpful
4answers
Excel Corruption files
Without seeing the file, it is difficult to diagnose what is going on, but I will offer some ideas.
What version of Excel are you using? Are you using Excel 2003? Was the file you are trying to open created in Excel 2007 or Excel 2010. If so, it might be using the new format and therefore will not open in Excel 2003 and older.
It is possible the Excel file is data that was imported from a source in which Excel cannot import. Does the Excel spreadsheet contain any imported data?
Try to use: XLSX Viewer Tool here : http://www.xlsx.viewertool.com/
Those are the most likely causes of the corrupt data. Is every file you open in Excel corrupt, or just this one workbook? If it is just this one workbook, then, yes, it sounds like it is corrupted. If every file you open with Excel is corrupt, then your version of Excel could be corrupt, but that is unlikely.
Can i export easy-mark label information into excel
On the File tab there is an Export/Import choice. Give it a try
Properties in importing excel table to an access table
This article explains how to import a Microsoft Excel file into Microsoft Access version 2.0 or 7.0. Microsoft Access can import files from Microsoft Excel version 2.0 through version 7.0. However, Microsoft Access cannot import Microsoft Excel 4.0 workbooks (.xlw). This article assumes that the Microsoft Excel file is using standard database formatting. That is:
To import a Microsoft Excel file in Microsoft Access 2.0 loadTOCNode(2, 'moreinformation');
  1. Save the file in Microsoft Excel using standard database formatting listed above. Close the file.
  2. Start Microsoft Access 2.0 and open the database you want to import the Microsoft Excel information into.
  3. On the File menu, click Import. From the Import dialog box, choose the appropriate version of Microsoft Excel that you are importing and click the OK button. Microsoft Excel 7.0 files are not on this list. If you are importing a version 7.0 file, choose the Microsoft Excel 5.0 option.
At this point options such as whether to append to an existing table or create a new table may be selected.
To import a Microsoft Excel file in Microsoft Access 7.0 loadTOCNode(2, 'moreinformation');
  2. Start Microsoft Access 7.0 and open the database you want to import the Microsoft Excel information into.
  3. On the File menu, click Get External Data and then click Import.
  4. From the import dialog box, choose Microsoft Excel (*.xls) for the Files Of Type option.
    This will display only the Microsoft Excel files.
  5. Find the desired file and click the Import button.
The Import Spreadsheet Wizard appears and allows you to choose options specific to the file.
or you just use the link for any problem where you can get details of the importing
http://www.techrepublic.com/article/techniques-for-successfully-importing-excel-data-into-access/5276622
1helpful
8answers
Repair corrupt excel file
Don\'t need to worry even if your excel
files are get corrupt because there are several ways to repair
corrupt excel files. The easiest available solution is to use "Open
and repair" utility of MS excel to repair damaged xlsx or xls files.
I just installed Easy-Mark on a vista computer. There were no problems during the install, but the program stops working when I try to open it.Is there a patch I can use to get this working on my machine?...
You can try to modify the following properties of the executable file, EasyMark.exe.
1. Use Compatibility Mode as "Windows XP SP2" to execute this program.
2. Under "Advance Properties", select the option to run this program as System Administrator.
9helpful
WHAT IS THE DIFFERENCE BETWEEN MICROSOFT EXCEL FROM DATA BASE
Excel is a spreadsheet - it is less structured than a database and all of the data appears on one (or more) pages along with many calculations and summaries of data.
A database is structured so that all the information is kept in the same format for each member record of the database - Databases are better at processing larger volumes of information.
Some tasks can be performed equally well in either spreadsheet or database -
Often data is stored in a database but analysis is done in the spreadsheet.
Excel Spreadsheet
It could have a virus or simply too much data in it or too much data linked to it. Try doing a copy of the whole spreadsheet, and then paste the data into a new spreadsheet. If it doesn't contain too many different formulas, try pasting only the values, and then replace the formulas manually. You might also try just deleting the links, if there are any. If this doesn't solve it, reply to this thread and let us know.
Hope this will FixYa!!!
I need to import data from access into excel where one column go into one worksheet and other into next worksheet
Acess will only export the data into an Excel spreadsheet with each element of the record going into a sperate column.
You can record macros to get the data to go where you want it to go on the spreadsheet.
2answers
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Open Questions:
See all Microsoft Excel for PC Questions
Top Microsoft Computers & Internet Experts
David Shaub
Steve Nordquist
Steve Nordquist
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
