I put a disc (dvd) in and it will start saying it's reading the disc and then will tell me no disc is inserted. CD's play well and so do picture DVD's. But no movies. The movies are brand new and not scratched.
Posted by jvcola on
Nanny
    Genius:
  • Audio Player... Master
  • 2,351 Answers
You can check on this for more solutions and details:
How to fix a DVD "No disc" error (3 solutions)
If you can't solve this, you can also download a free Blu-ray player program which can be an alternative to it, such as Leawo Blu-ray Player
Posted on May 21, 2020
efs_perpends
    President:
  • 1,997 Answers
Picture dvds are read with different software than that required to play movies. Make sure that you actually have dvd player software installed on your system, like WindDVD or Power DVD. See this link for a few.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 30, 2009
This is a video that I made and want to copy. Toast will make a disc image, it puts the picture of the 2 clips, and then says "could not record the disc because a file could not be found" Result code
Your burner program wants to make an image so the video can be played in a DVD player. If the format is not correct it don't want to burn the disk. Please read the manual from the burner program, or press the F1 key before you start. I hope they inserted some help in the program.
Jan 13, 2015 | Roxio new toast 7 titanium/en cd mac roxio
I have a philips hts6510 home theatre system and when i put a dvd in to play it says no disc
hi,
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips HTS-6500/37 System
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a sanyo 3 disc dvd changer. says no play
first of all you need to check your manuel for dvd's that can be played as in burnt. as of right no cd/dvd changers can play dvd that are burnt. cd's can be played if it states on player. only normal cd's and dvd's can be played. also check your disc for marks on them like fingerprints etc. if you want invest in a great player like sony, pioneer, i have no problem with these players.
Jul 26, 2009 | Electronics - Others
My 14" dvd combi player wont read any disc i put in. The only thing that happens is that the main screen says reading disc then about 1 minute later is says please insert a playable disc. I have tried...
The optics can not read the disc. Try cleaning the lens inside using a cotton swab and alcohol. Also try playing a music CD. If the CD plays but a DVD continues to fail, the opticsl will need to be replaced. Depending upon the specific model, this could cost anywhere from $50-$120.
Dan
May 20, 2008 | Philips Televison & Video
Cannot read disc, unable to recognize..........HELP
In order to finalize your disc the dc210 MUST be plug into an outlet!!!
Oct 29, 2007 | Canon DC210 DVD Camcorder
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
90 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
