Usb is not recognizing plug-in
How do i get my computer to recognize my usb plug in? When i plug it in it does not even recognize it on the computer.
Posted by oif_vet_27 on
  • Anonymous May 11, 2010
    What computer and what usb device?
  • Gloria
    Gloria Dec 29, 2013
    windows 7 computer and nokia lumina 2520
Anonymous
    Problem Solver:
  • 11 Answers
May the usb device in your bios is disable. you must enable the usb device in your bios to recgnice your usb. you must enter to the bios setup to config. the usb configuration.
Posted on May 01, 2009
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
Laptop will no longer recognize
Test to see if the computer sees another USB device like a keyboard, if it does, this means your USB port is working.
Plug the device into another computer, even go to a computer sales store and plug it into one there to see if it works. if it does not work, the KP25B is dead and needs to be replaced. if it does recognize it, then use a different USB port on the computer.
Feb 27, 2011 | Micro Innovations KP25B (KP25BEA)
I was checking some of the files on my usb. When it became unresponsive I rebooted it. After doing so, my usb ports wouldn't recognize any usbs(camera, printer, etc.) I kept trying and I got them to work...
Hi. If your saying that you're USB is not being recognize by your computer then you should try that USB on a different machine and try if its working there, and if yes the problem is with your computer you just need to update the drivers on your computer to recognize your USB, and if not I think the USB has the hardware issue. Hope This Helps
Jun 04, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Usb device not recognized
If you are using Win98, that is the problem, as I think SP2 had an update to use USB, but it was iffy. See if you can download that part from Msoft. for starters. Test it on a WinXP or Vista machine, if it is not recognized, it is probably bad.
Aug 26, 2009 | Microsoft Windows 98 for PC
Computer not recognizing usb connected nav device
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 05, 2009 | Magellan Maestro 3200 GPS
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
USB External storage device not working properly
please update the USB Drivers and if that Doesnot Work then Update the BIOS of you Computer from the Manufacturers Web site
Nov 01, 2008 | Dell Computers & Internet
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
Computers & Internet Logo
157 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
