Question about Hitachi 51S500 51" Rear Projection HDTV-Ready Television
SOURCE: Hitachi 51S500 51 in.
check the lamps again you could still have a bad one
Posted on Oct 20, 2008
SOURCE: attach laptop to hitachi 51s500 tv
See if on the back of the TV, and on the computer you have an external type VGA type connector. You then have to purchase a long VGA interface cable to go between the laptop and the TV set.
The TV must be compatible to receive the VGA and external audio from your computer, and the computer must be capable to drive external audio/video devices.
Another issue that must be worked out is both the TV and computer must have compatible screen resolution rates. You will have to get the information about the display card in the computer, and compare it to the specs of the TV set. If these do not match up in to proper range you will either have a very stretched or compressed picture, or you may not be able to have any results at all.
If the scan rates are too far out, it is possible to damage the TV set!
If everything is technically correct, you will also have to purchase compatible cables to go from the lap top external audio output to the correlated audio input connectors on the TV. This is an adapter type audio cable.
For these cables, you will have to determine the connector end types on each of the units, so that you can go to any audio/video supply store and properly pick them out.
There is a simpler solution, but it will not have good picture quality. You can buy a VGA to baseband video converter box (if these are still available). These are not cheap but they can work if set up properly and the scan rates can be matched. You attach the converter box to the external VGA port on the computer, and then use its output via the proper baseband video cables to drive the TV set. The scan rates will still have to match. The quality will be very poor.
Jerry G.
Posted on Nov 14, 2009
Testimonial: "helpful but you still have to be a brain to find the right cables...."
Aug 19, 2016 | Hitachi Televison & Video
May 05, 2012 | Hitachi 51S500 51" Rear Projection...
Mar 14, 2011 | Hitachi 51S500 51" Rear Projection...
Nov 04, 2010 | Hitachi Televison & Video
Nov 14, 2009 | Hitachi 51S500 51" Rear Projection...
Oct 04, 2009 | Hitachi 51S500 51" Rear Projection...
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
Aug 22, 2009 | Hitachi 51S500 51" Rear Projection...
Jul 03, 2008 | Hitachi 51S500 51" Rear Projection...
Dec 25, 2007 | Hitachi 51S500 51" Rear Projection...
Jan 02, 2015 | Hitachi 51S500 51" Rear Projection...
