Question about Sanyo SR-4911M Compact Refrigerator
Refrigerator compressor hot not cooling - Sanyo SR-4911M Compact Refrigerator
2 Suggested Answers
sur singh
  • 51 Answers
SOURCE: My Sanyo SR-4911m refrigerator does not cool.
make on thermostate and check compressure working or not
Posted on Dec 01, 2010
canwoodjc
Canwoodjc
  • 3301 Answers
it shouldn't be gurgling, has it been laid on its side at some point? anyway,, sounds like it has air in the system,, unplug it and let it stand upright for 24 hours, if the problem still persists,, it may need to be charged, the compressor getting hot is normal , if its very very hot, its because its running constantly trying to cool the unit
Posted on Jul 04, 2011
How do I determine if need refrigerant? Compressor is running hot and 2nd thermal protector has to be bypassed
More than likely one of your external coil cooling fans is not operating. OR Access for the fan to blow cooling air is blocked, or the cooling coil is so dirty the fan air is not effective in cooling the coil. Refrigerators are a sealed system. If the compressor has gotten so hot that the motor has burned you might as well find a lightly used replacement. It will probably be less than a repair by a qualified technician. Even if I told you how to replace the refrigerant the stores would not sell it to you. This is not a car Air conditioner! If you lost refrigerant it has probably burned the compressor motor. The refrigerant "acts" like a cooling system for the compressor motor.
Mar 07, 2015 | Danby Designer DAR440W / DAR440BL Compact...
Compressor is running but not cooling.
A few things to check are is thier frost build up in the freezer?
or is the compressor not to hot,if it is hot it should be working ok
oddly enough if it isnt too hot its because all the refrigerant is leaked out and it doesnt have to work hard to pump it so its kinda cool,a compressor that is pumping the refrigerant (freon) its working hard and hot
Gene
Aug 11, 2011 | Whirlpool GS6NBEXR Side by Side...
My Sanyo SR-4911m refrigerator does not cool. Compressor seems to turn on when termostat is turn from off position to on position. However, compressor gets really hot and gurgles, but does not cool the...
Jul 04, 2011 | Sanyo SR-4911M Compact Refrigerator
Compressor working, cooling coils hot, but unit won't cool below
When you say fully charged, did you weigh the refrigerant? These small systems cannot tolerate overcharging by even small amounts because it will result in overpressure on the suction side. If there's too much refrigerant you get hot coils and cool but not cold evaporator. I typically pump the refrigerant into a recovery tank and then weigh it back in to get exactly the amount on the mfg label.
Dec 12, 2009 | True 598-TSSU608ADA SandwichSalad Unit 155...
Gold Whirlpool 25.3 cu.ft refrigerator stop working
if the compressor is very hot then it can be possible that the compressor is getting faulty,but also other possibility can be the compressor relay.if the relay beside the compressor is got faulty then the compressor gets over heated.so first unplug the unit from main power outlet and then remove the relay and check it with continuity to confirm the fault.is it relay or compressor.
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator dosen't cool or freeze
the hot piece is the compressor.the clicking is the relay trying to start the compressor.generaly when im out on a service call and the compressor is hot and relay clicking the compressor has failed internally.because if the relay was clicking but the compressor was not hot there was a chance only the relay was bad and not allowing power into the compressor.but because the compressor is hot that tells me the relay is letting the power to the compressor but the compressor cant do anything with it because it locked up and its absorbing that power getting hot and then clicking on overload you could try a relay but i don't think it will help. God bless ,tom
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator housing is getting very hot
this is for sure the reeason for the heat between the doors, in mean time ( whike waitin got replace the fan behind the compressor, you can install a small cheap house fan behind unit to keep it cool , ohterwise it will eventually damage the compressor
Jan 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Sanyo SR-4911M Compact Refrigerator Logo
76 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
David Soto
David Soto
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
