Macally BTMicro Mouse Logo
Posted on Oct 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble pairing my bluetooth Macally BT micro mouse
I am having trouble pairing my bluetooth Macally BT micro mouse. Even after pushing the pairing button, the infared light doesn't come on momre than half the time, and soemtimes my computer will see the mouse to the point where I can hit the mouse buttons and scroll wheel, but the cursor won't move.
  • kimmac Nov 20, 2007
    I am having the exact same problem with my mouse. It has always done this..
Thomas Christopher
Level 3:
Genius:
  • Master 1,601 Answers
  • Posted on Nov 23, 2007
Thomas Christopher
Master
Level 3:
Genius:
Answers
1601
Questions
Helped
1052660
Points
3958
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
2answers
How to pair craig cma3532bt
To Pair:
1. Turn on your Bluetooth speaker/headphones (slide switch to BT)
2. Light should turn on Blue. If not, plug speaker into USB connector and light will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
I can't operate the mouse. its not working.
Install fresh batteries, turn it on and make sure your bluetooth dongle is installed and active. If you have never paired this mouse with it's receiver, then you will have to put them both into pairing mode, and once paired you should have no problems.
31helpful
How do i pair my bt4517 headset?
you need to switch on the bluetooth on your mobile. then switch on the headset (by holding the call button for few second). you will see blue light flashing. now to pair them with ur mobile click the volume controls (+ and -) on heatdset together for two second and search for the bluetooth head set in ur mobile it will detect it as BT*** just give the pass code 1234 and there you go. hope this helps. the instruction is there in the box!!!
Got this elsewhere - tried it - it worked !
2answers
Bluetooth mouse not working
you can turn off and on the Bluetooth and try it out. If not you might want to check your battery status.
Another option could be to re-pair it to the BT.
88helpful
12answers
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
1helpful
Pairing my Macally BT micro mouse
2answers
Bluetooth and infared
check your imei and bt mac adress.if they are not paired,bt and ir port will not work.other thing that may be wrong is bt module itself,that got damaged after the fall of the phone
The mouse keeps getting erased from the Bluetooth Devices Menu
Try pairing again.
Or re-install the bluetooth driver.
Top Macally Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
