Question about Canon PIXMA MP830 All-In-One InkJet Printer
Pixma ip4500 orange light blinks 12 times...Support Code : 6A00 A printer error has occurred. Turn the printer off and then on again. If this doesn't clear the error, the printer needs repair. See the manual and contact the service center? any way i can fix it myself? no paper jammed. one minute it was working, the next it's blinking this error
5 Related Answers
Anonymous
SOURCE: error 6A00
I just had the same problem :( I dont have a true fix, but I slid out the cartridge to the left and back in. I read it had to do with a timing mark somewhere. When I powered it back up. It went back to normal
Posted on Jan 27, 2008
Anonymous
  • 6 Answers
SOURCE: Had paper jam. Now PIXMA IP5000 shows service
Print head might be stuck. Try opening the lid and sliding the cartridge tray over to the left. Check to make sure there is no piece of paper left jamming it. While you are at it, clean the base pad by dabbing with a piece of paper towel to remove excess ink. You may also want to remove the Print head itself and then reattach. Make sure there is no gunk buildup. Hope this helps.
Posted on Sep 07, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: My canon ip1200 printer has stopped printing.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
puertobori
  • 7733 Answers
SOURCE: I get 12 orange blinks.
Shure is your Mod- # ? go to LINK.
Posted on Oct 24, 2010
My IP4500 orange lights blinks 15 times. How do i fix this
Hello!
Please check your printer LCD. You may see some error on your printer LCD code that Error Number and send back to me. I will try to solve your printer as much as I can... thanks
Sep 11, 2011 | Canon Pixma iP4500 InkJet Printer
Mx850 canon all in one. was working fine then the alarm light came on and screen shows error code 6A00??? have tired moving the ink cartrigde device, unplugged and pluged back in ... checked everywhere...
6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
Dec 31, 2010 | Canon PIXMA MX850 Multifunction Printer
Says Check printer 6A00. Any ideas?
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error 6A00
May 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Printer is flashing orange in equal increments. When printing, I get the error message 6A00. It tells me to turn the printer off then on again. I turn it off an on again, but this does not fix the problem....
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 02, 2009 | Canon Pixma iP4500 InkJet Printer
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
208 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
