Question about Lenovo ThinkPad Computers & Internet
Thin vertical line on laptop screen - ThinkPad Lenovo Computers & Internet
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: Vertical lines in my laptop screen
A VGA monitor is a monitor that uses a standard VGA connector to attach to your PC/laptop. A VGA connector is a small D shaped socket connector, about ½ inch long and ¼ inch wide. Its usually blue with three rows of holes (total of 15 holes) where pins from the mating connector match up with. The only other thing that may look like it is a serial port but that is easy to distinguish, it has two rows of pins for a total of 9. What 24 sever is suggesting you do is connect another monitor to see if the problem shows up there as well. I?ll be surprised if it does since usually this type of display problem on a laptop more often than not is due to a defective connection inside the laptop screen area. A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change. If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you?re lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on or take it to your local repair shop.
Posted on Jul 22, 2007
Anonymous
  • 624 Answers
This appears to be a duplicate posting, see this link for the active post: http://www.fixya.com/support/t152864-vertical_lines_in_laptop_screen
Anonymous
  • 84 Answers
There could be three different possibilities why you would get a line on your lcd display.
First, it could be a missing signal from the controller IC to LCD driver IC
Second it could be a defective LCD driver IC itself
Third it could be a dry contact in the tape carrier package ( TCP).
Attach an external monitor to your laptop and make it your primary display unit to see if you are still getting the lines if not its you TCP if you still get lines it will need to have either the LCD IC or the controller IC checked and possibly replaced.
Posted on Feb 11, 2008
Anonymous
  • 57 Answers
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
Posted on May 23, 2008
mspcrepair
Scott Merrill
  • 169 Answers
I know not everyone has this ability, but if you can, go to a friend's house and hook up an external monitor to your laptop. You may need to use the function keys to switch from LCD to external, but if the lines go away on the external, you have a bad LCD. If the line shows up still on the external, then your problem is either:
a) video driver (free, easy fix)
b) bad inverter (video 'outputter') ...approximately $10-50/varies + labor costs to replace
c) bad video card/motherboard ...usually between $200-$400 + labor to replace
Hope this helps - please be sure to rate my answer :)
Posted on Sep 29, 2008
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Thin vertical green line
Could you please specify what type of screen this is? Or any other information that could help identify what type of screen it is?
A thin vertical line in a screen could be a faulty cable, faulty graphics card or even that the screen is faulty itself. But with more information on the screen the problem would become clearer.
Aug 27, 2013 | Dell Computers & Internet
I have a thin horizontal line across my dell latitude laptop screen
If the thin line is always there, you have a set of pixels burned out. This usually occures vertically. There is easy fix, except to replace the screen. If the laptop is under warrenty, contact the manufacture for repair options.
Sorry could not be something easier for you.
Mar 19, 2012 | Dell Latitude D630 Notebook
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
Blue vertical thin line on Acer Travelmate 2410
It might be the case that the pixels of that line have become dead.This is a monitor malfunctioning and you shud report to your vendor.
Feb 04, 2008 | Computers & Internet
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Nov 26, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Computers & Internet Logo
18 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
