Question about Rival Food Slicer
The thickness gage is stuck
How can i get the thickness gage to move?
Larry Allin
    New Friend:
  • 26 Answers
If you still have this problem, please provide details of the problem. Rival 1030 and 1101 series slicers had design changes over their run and several thickness mechanisms were used. Please describe; can you see the working parts or are they enclosed? Is the adjusting handle a crank like used on old-fashioned pencil sharpeners or more like those used on a manual can opener?
Posted on Jun 24, 2015
Got a thick envelope stuck. Tried to reverse, but doesn't move.
Please, what are you talking about?
After far more thinking than your Question deserved, I realise you mean you got a thick envelope stuck...
If that's what happened then first, what thickness does your printer's manual say is acceptable?
Jul 13, 2018 | Office Equipment & Supplies
My gas gauge is stuck how do I fix it on a 1970 olds delta 88
if you disconnect the wire at the sensor or down from the sensor were you can get to it the gage should register empty and if you disconnect the ground it should register full. if nothing happens then the gage on the dash is bad, if gage moves the fuel level sensor in the tank is bad.
Aug 24, 2014 | Cars & Trucks
Why is oil gage reading 60? does this mean I need oil?
CHECK OIL PRESSURE FIRST.DEPENDS ON THE ENGINES SIZE JEEP OIL PRESSURE RANGES FROM 25 PSI TO 37 PSI.IF PRESSURE CHECKS OUT GOOD GAUGE COULD BE FAULTY.IF OIL PRESSURE IS STILL TOO HIGH.YOUR OIL TOO THICK.OIL RETURN HOLE STOPPED UP.OIL PUMP PRESSURE REGULATOR STUCK CLOSED.
Apr 11, 2010 | 2000 Jeep Grand Cherokee
Heater not working
It sounds like the thermostat is stuck open.
Feb 24, 2010 | Mazda 323 Cars & Trucks
Oil pressure gage stuck on high
HI, you will need to replace the oil pressure sending unit(pressure switch), it has failed.
Jun 21, 2009 | 2003 Chevrolet Tahoe
Gas gage does not move stuck on 1/4 tank
1. is it stuck at !/4 tank when it is turned off?
2.have a scan tool hooked up to it see if it has an option for functional tests some you can select interior-dash and test gauges if you can that is an easy way to see if it works
Apr 24, 2009 | 1999 Ford Explorer
My fuel gage is stuck at 3/4 of tank in my 84 chevy silverado
take the wire off that goes to the tank and ground it. if the Gage moves then it is the float if the Gage stays there then it is the Gage.
Mar 24, 2009 | 1984 Chevrolet Chevy
Coil instalation is it nessary to gage coil
Use a stiff piece of paper the thickness of a a buisness card withmagnets on one side and the col on the other. Move flywheel while tight, without tearing the card paper.
Feb 28, 2009 | Husqvarna Forest & Garden No.967012396 345...
Fuel gage stuck on a 2004 Buick Rendezvous
TRY REPLACING FUEL PUMP IF IN TANK THE FUEL GAUGE GET ITS SINGAL FROM THERE
Feb 14, 2009 | 1989 Chevrolet K1500
Gas gage stuck
Sounds like your fuel level sending unit is bad. This is a common problem with these and my 190E is doing the same thing. They are very easy to replace. If you decide to do it get beck to me and I will walk you through it.
Aug 25, 2008 | 1984 Mercedes-Benz 190
Rival Food Slicer Logo
347 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
