Question about Husqvarna Viking 1
The screen on my viking designer se/le goes black
I can sew but the screen goes blank. I have tried to shut it of but I have to leave it off like 20 minutes whats wrong
Posted by Beverley Osterwyk on
MissFixIt828
    New Friend:
  • 70 Answers
Your screen may need to be replaced. Take it to a husqvarna dealer and see if you can get a free estimate.
Posted on Nov 06, 2013
  • MissFixIt828 Nov 06, 2013
5 Related Answers
dupina
Theo du Preez
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
Anonymous
SOURCE: viking designer se limited
You can find this information by touching the configuration icon (this looks like pliers). The item that shows you how many sewing hours is called Timer. You should know that this can be reset to 0 by anyone.
Posted on Dec 29, 2008
Anonymous
  • 87 Answers
SOURCE: husqvarna designer se
There are 3 main fixes for a freezing SE.
1> Have the latest 12501 update installed, the 12124 had a problem.
2> make sure you have the right hook (the 2 older hooks have this problem.
3> The newer tension assembly with the grounding strap needs to be in the SE as well.
4> there were only suppose to be 3 but if your screen gets weird when it freezes, it could be the video transformer
Posted on Mar 18, 2009
radcal
  • 196 Answers
SOURCE: viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Posted on Apr 20, 2009
deborahcha
  • 371 Answers
SOURCE: I recently purchased a Husqvarna
Sorry. Sounds like a dead LCD screen. It will have to be replaced by an authorized Husqvarna Viking dealer. Be sure it is an authorized dealer. Check the Husqvarna Viking website for dealers close to you. Http://www.husqvarnaviking.com/us
Posted on Sep 24, 2009
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
Screen goes blank and then stops sewing. I have a Bernina Aura 440QE 8years old.
You should probably take it to Bernina for repair. Sounds like possibly a board or component.
Nov 08, 2015 | Bernina Sewing Machines
My juki sewing machine is not threading right it cuts the understich as it goes thru and leaves a big pile of thread on the bottom when back stitching what's wrong with it?
it appears the basically the needle thread tension is not set right
try increasing the tension of that thread
next check the needle /hook timing
Jun 25, 2015 | Juki Sewing Machines
Why does the screen on my viking designer 1 se/le go blank but still sews
the motherboard or screen could be going out, it would be a good idea to have the machine checked
Nov 06, 2013 | Husqvarna Sewing Machines
Janome 5900 - screen lights up but is completely blank - what's wrong with my machine?
could be the motherboard is going out, it would be a good idea to have the machine checked at a sewing machine shop.
Jul 12, 2013 | Sewing Machines
Blank screen
time to have the machine checked to see if there is something wrong with the motherboard..
May 27, 2013 | Janome Memory Craft 9000 Computerized...
Machine just stops but power is on
that is the power board (in base plate) you need a rebuilt base plate. Unless you can rebuild the power board. You can buy a rebuilt board and send your in and receive a core credit. It still will probably run $200 to get one. It will also come with a 2 year warranty.
Mar 16, 2009 | PfaFF Tiptronic 2030
Bernina 440 QE -- Freezing with blank display
Definatly it is an electronic issue. Have the cables checked to be sure there weren't any pinched between the covers etc. And that the plugs on them are seated properly. This they should do naturally. I have also seen this before when what is called the EEPROM chip went bad. Screen lit, no info. The EEPROM is a small chip, black and rectangular on the S-Print board,The EEPROM stores all the information for the machine to work. The screen will light but no info on the screen if its bad. Before replacing a whole circuitboard I would suggest replacing this. It just plugs and unplugs from the S-Print and much less expensive.
If your not feeling all that trustworthy if the tech can do it then ask that it be sent to Bernina in Illinois and repaired. It could take 6 weeks though.
Jan 10, 2009 | Bernina Activa 140
Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Nov 08, 2008 | PfaFF Sewing Machines
Sewing Machines Logo
168 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
