Question about Pentax *ist DS Digital Camera
Clicking sound - Pentax *ist DS Digital Camera
My 2015 subaru outback 3.6 r makes a clicking sound when I floor the acceleration and it clicks while accelerating.
2011 3.6R Back Seat or Door Rattle / Click Sound - Subaru Outback ...
www.subaruoutback.org > ... > Models > Gen 4: 2010-2014
Dec 3, 2011 - 2011 3.6R Back Seat or Door Rattle / Click Sound ... The latch can bang into the plastic cover making a rattle sound. See More is offline. Clicking sound on stopped car with brake pedal
Oct 25, 2015
Yet another clicking sound. But in console and sounds like a relay ...
Jan 1, 2011
Clicking Sound After Engine Turned Off - Subaru Outback ...
May 30, 2010
Engine ticking sound? - Subaru Outback
Apr 4, 2010
More results from www.subaruoutback.org
2013 Subaru Outback Shifter makes clicking sound at low ...
? 0:07
www.youtube.com/watch?v=AUAKNhxKWTM
Jan 8, 2015 - Uploaded by Eric Seeger
I noticed this sound occurs during low speed stop and go driving. This video was ... 2013 Subaru Outback Shifter makes clicking sound at low speed braking. ... 2015 Subaru Legacy Challenges the Roadkill Project Cars! ... 2013 Subaru outback 3.6R up hill in snow - Duration: 1:47. by davidlcb 13,610 views.
Nov 13, 2015 | Subaru Cars & Trucks
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
How to deactivate shift key sound on windows keyboard
Right click on the speaker icon in the bottom taskbar select playback devices then sounds tab scroll through all device sounds select it then from the drop down list select none
this will vary depending on your operating system
or
Click "Start."
Click "Control Panel."
Click the "Sound" icon.
Click the "Sounds" tab.
Click on the listing for the sound that currently plays when an action is performed on your keyboard.
This will select it. Click the drop down menu on screen and select "None." Click "Apply" to disable the keyboard sound in
hope this helps
Oct 10, 2012 | Computers & Internet
I was messing with the sound settings and now every sound or music that comes out of the speakers sound like chipmunks (high pitch voice) even the even sounds weird.. And I dont remember or know how to fix...
Right-click the desktop and select Personalization then click Sounds and change the Sound Scheme to non,that is for windows 7.
For XP Go to Start / Settings / Control Panel and then select "Sounds and Audio Devices"
Now click on the "Sounds" tab as shown and select the "Start Windows" sound also as shown.
Where it says "Windows XP Start up" change this to "None" and you will be OK
1. Click Start, click Control Panel, click Hardware and Sound, and then click Sound.
2. In the Sound window click on the Sounds (tab).
3. You will see a box with a list of items one being Asterisk.
4. Click on Asterisk, or any item in that box, and then click Test.
5. You should hear audio coming from your system.
6. If the clip was not long enough select another item, and then click Test.
7. Determine whether or not the distorted audio is present.
Configure the speakers
2. In the Sound window right-click your Speakers and select Configure Speakers.
3. Follow the on-screen setup, and Test the available configurations.
4. Identify whether or not one configuration appears to have less of an "echo" than others.
5. If the issue is resolved by modifying the configuration then you do not need to do anything further.
These fixes only work for windows and not any third party software.So if you have a sound card,you will have to use the app for it.
May 20, 2011 | Computers & Internet
Music in power point presentations
  1. Display the slide to which you want to add music or sound effects.
  2. On the Insert menu, point to Movies and Sounds, and then do one of the following:
za079005000.gifInsert a sound file
za079005000.gifInsert a sound clip from Clip Organizer
  1. Double-click the sound file that you want to insert.
  2. When a message is displayed, do one of the following:
    • To play the music or sound automatically when you go to the slide, clickAutomatically.
    • To play the music or sound only when you click the sound icon za006052183.gif, clickWhen Clicked.
  3. To adjust the settings for when the sound file stops, click the sound icon za006052183.gif, right-click, and then click Custom Animation.
  4. In the Custom Animation task pane, click the arrow on the selected item in the Custom Animation list, and then click Effect Options.
  5. On the Effect tab, under Stop playing, do one of the following:
    • To stop the sound file on mouse-click of this slide, select On click (the default).
    • To stop the sound file after this slide, select After current slide.
    • To keep the sound file playing for several slides, select After, and then set the total number of slides the file should play on.
Mar 24, 2011 | Microsoft Windows Vista Home Basic Edition
My pc there was no sound
1st you check is your sound card driver install properly. OR Check your is your sound mute from sound card driver. Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager then Double Click on Sound, video and game controller. There are list where you check is the sound card driver is available. If it is not available then Install the driver. Installation of Sound Card. Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager then Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it. Right click on Multimedia Controller and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install if the problem is still exist. Replace the sound card or have a local tech take a look at the sound card.
Apr 24, 2010 | Creative Labs Sound Blaster Live! 5.1...
How to reinstall sound card
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Double Click on Sound, video and game controller.
  • There are list where you check is the sound card driver is available.
  • If it is not available then Install the driver.
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
  • Sound Card Drivers
Apr 18, 2010 | IBM AUDIO BOARD 92G7566 Sound Card
I have no sound in my pc, compaq evo d320. a already install the sound driver. but still no sound.
  • Sound Drivers
Apr 17, 2010 | Computers & Internet
My sound card have install but he does not work proper and i have not softwear install
You should update your sound driver. Update of Sound Card Driver.
  • Click on Sound, Video and game controller
  • Right click on sound driver from the list.
  • Click on Update Driver.
  • Update Driver Wizard start.
  • Creative Sound Card
Apr 03, 2010 | Creative Labs Sound Blaster Live! 5.1...
I have a lot of echo in the sound how do I fix this
  • You should update your sound driver. Update of Sound Card Driver.
  • Replace the sound card or have a local tech take a look at the sound card.Sound Card Drivers
Mar 15, 2010 | Gateway (6000161) Sound Card
Pentax *ist DS Digital Camera Logo
91 people viewed this question
Top Pentax Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
halotheracer
halotheracer
Lee Hodgson
Lee Hodgson
Are you a Pentax Camera Expert? Answer questions, earn points and help others
