Question about Davis Instruments Davis Vantage Vue Weather Station
Outside temp For some reason my console is no longer displaying the outside temperature. All other readings seem to be fine. I have done the following: 1. Replace the batteries in the console and did a complete restart. 2. Removed, cleaned and reinstalled the radiation screen
Posted by Jerry wall on
My weather station is no longer recieving an outdoor temperature reading. The barometer is working fine, as is the indoor base station. Both were given new batteries at the same time, and the set up i
hi,
does the outside humidity working ?
if yes - the outside station is transmitting but the temperature sensor is faulty,
if no sensing is available from the outside station, it look like the outside station is faulty . (this is common because of extreme weather change.
notice that the pressure sense is done in the base station.
regards ,
Daniel
https://www.rylwy.com/
Nov 23, 2017 | Measuring Tools & Sensors
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
A/C blows but not cold air....the temperature reading is off...but then sometimes the temperature reading is fine and the air works
The outside air temperature is reading sometimes off then the ac does not work? The ambient air temperature sensor located right by the front grill is probably malfunctioning.If it reads below a certain temp it sees no reason to turn the air on so it doesn't let you.
Jul 17, 2010 | 2000 Pontiac Grand Prix
Outside temperature display don't work
If the dome lights work and the console display is dead then it is not a fuse issue as power is directed to the entire assembly.
This is a very common problem with many of the mid 2000 Ford truck and SUV overhead consoles. The console is very prone to internal failure. I offer a reasonable repair service with a lifetime guarantee, check it out: www.autoclockrepair.com
There is a bunch of useful info there. Drop me an email if you have questions, thanks!
May 15, 2010 | 2002 Ford Expedition
Display - outside temperature and compass
The overhead console is quite prone to internal failure. Dim, intermittent, or dead displays are a common symptom of an internal failure. We offer a reasonable repair service with a lifetime guarantee. Check it out: www.autoclockrepair.com
Jan 23, 2010 | 2002 Ford Expedition
The outside air temperature sensor for the 2003 Camry
the sensor is located in front of radiator if you open hood and look down behind front bumper you should see it, or look from under the frt bumper, it easy to change, also get part from dealer it not $$,hope this helps.
Nov 28, 2009 | 2003 Toyota Camry
Thermometer not reading correctly
I would guess the outside thermometer has lost its calibration.
Does it seem consistently 5, 10 or 20 degrees off all the time?
Let me know.
Regards,
Apr 25, 2009 | 1991 Buick Park Avenue
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Davis Instruments Davis Vantage Vue Weather Station Logo
616 people viewed this question
Top Davis Instruments Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Davis Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
