Question about Motorola TLKR T5 Two Way Radio
The speaker sounds tinny and has lack of volume
Posted by Jimmy on
Anthony Chard
    New Friend:
  • 17 Answers
Sounds like the speaker got wet. If there is an earphone socket, does that sound OK ? If so, the speaker is your problem and must be changed out.
Posted on Nov 06, 2013
How do I hook up a home theater system to my sansui record player? DO I need any special hook up? Where is the volume controlled?
Some make and model numbers would have helped.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance (*) the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Lacking a Phono Preamp you will have unusuable very low, tinny sound.
* Google "riaa equalization" for some background
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment.
Volume is always handled at the electronics.
Jan 30, 2011 | Audio Players & Recorders
The Volume goes nice and loud but the sound is tinny.
At bottom right of our screen you will see an icon for the volume (shape of a speaker). Double click on the icon to access the full volume control dialog box. Try in creasing the volume from here and set it to a reasonable level. Once set, you can use the volume control on your monitor.
Jun 25, 2010 | HP Vs17 17" LCD Flat Panel Monitor
The right speaker produces almost no sound
This can happen due to several reasons.
You just check whether th wire got bend . It can happen due to that.
-rate if it helped you.
Apr 08, 2010 | Bose Companion 2 Series II Multimedia...
Tinny sound from L-310 SW's
This might be helpful. Most stereo receivers have 2 sets of speaker outputs, A and B. Each have outputs for left and right speakers. On the front panel of the receiver, there should be a switch to turn on/off speaker A/B. When using both A and B, (a set of speakers on each A and B) you will lose a bit of volume.
Another possibility is, if the speaker cable length to your covered porch is a long distance from the receiver, you will lose some power from the receiver. Try using a thicker gauge speaker cable for longer cable runs. Try 14 gauge or 16 gauge.
Apr 06, 2010 | A D S L310 Main / Stereo Speaker
Alarm clock
The clock radio is mediocre, according to at least 15% of owners. First, the radio reception lacks clarity and the sound is tinny. Second, there are many small buttons and it's impossible to tell which is which in a dark room. Third, because the volume and radio tuner are adjusted by moving a dial, it is easy to accidentally move the device and turn down the volume as a result. This can be a problem if you've set the clock-radio alarm and the radio volume is too low.Kindly check these first.
Jan 27, 2010 | Homedics Sound Spa Classic Clock Radio
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
1 X 1200Mk2deck higher volume / causing spkr not to work..
Problem If you swapped the two TT's would the problem stay with the connection on your mixer? At least then you/we would know wherein lies the problem. I'm betting thge low volume is because you have the phono jacked into a line level input like AUX instead of PHONO.
Typically, what you're describing is a phone source plugged into a NON-phono connection. (Tinny, low volume - classic lack of a phono preamplifier with RIAA equaliztion). A standard old-school tuntable requires a phono preamp that is labeled "PHONO". Nothing else will give it the boost and freq response correction LP's and phono cartridges produce.
Your problem #2 alludes to a channel problem with a turntable running through your mixer. This isn't rocket science. Swapping the two turntable channels around would probably change the apparent failing channel, right? Yes - Problem out at the turntable. No - problem in the mixer. You've already hinted at the source by monkeying with the tonearm wiring. You're on the right track. The tiny multi-colored wires in the cartridge shell are very thin and delicate. Their brass fittings sometimes oxidize and reseating them as you have done usually gives some relief. Kinks in the wires could cause your intermittent symptom. At the RCA end of the tonearm cables, make sure they're seated on with a twist to wipe off oxide.
Problem #3. Is it just bothering you or is there a functional problem, too?
Apr 21, 2009 | Technics SL-1210 Turntable
Bass tone problem
Both of your problem amps were made in the '70's or earlier. It is entirely possible that the coupling capacitors are failing. This is an issue for a service center whether it is caps or something else, like failing tubes.
The good news is that installing metalized polypropelene capacitors will make those classic amps sound incredible.
Nov 04, 2008 | 3Com SuperStack II advanced RPS...
Motorola TLKR T5  Two Way Radio Logo
73 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Jane
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
