The message centre ensures that your text message is sent to the recipient. If the wrong message centre number is saved in your phone, the text message can't be sent.
Set up your phone for text messaging
Find "Text messages"
Press the message icon.
Press the menu icon.
Press Settings.
Press Text messages. Save the message centre number
Press Message centre.
Key in +35387699989 and press OK. Return to the home screen
Press the Home key to return to the home screen.
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone. Presss *#0000# to display phone factory information and firmware Now press options and select check for updates The newest update is sent to your phone from nokia Download and install updates. This is done using GPRS or WIFI Connectivity.
General Tips ========= 1. Use Dialer and press # for about 2
seconds will switch the profile between Silent and General; press and
hold 0 will open the web browser; press and hold 1 will open the voice
mailbox
2. There is a shortcut key for Music, Gallery, Share,
Video, Web shortcut at the top right corner just below the front camera
3.
Press and hold the Green caller button when standby mode will activate
the voice command. You could call the name from the contact or
application name.
4. Organize your sms by grouping them like
outlook by Messaging -> Option -> Setting -> Text message ->
Other -> Show messages in groups -> Yes
5. Notification
light will blink if there is unread sms/missed call. It could be turned
off at Settings -> Notification light -> Off
6. If the
touch input is not accurate, you could calibrate your screen at Touch
Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the
corner)
7. Turning control functions: a. Rotate your screen
horizontal or vertical b. Silence your phone for incoming call by
rotate your phone with screen facing down. c. Snooze the alarm by
rotating phone screen facing down
8. Theme effect will give 3D
and transition effect if on but will slow down your tube considerably.
Settings -> Personal -> Themes -> General -> Themes effects
-> On/Off
9. Shortcut to exit application : Press and hold the
middle white button then press and hold the program that you wish to
quit, an open/exit option will pop out (useful for those haven’t install
handy taskman yet)
10. When using handwriting input, slide from
left to right is Spacebar, right to left is Backspace
11.
Organize your menu by Menu -> option -> organize. You could drag
and drop the location of the application you wish to relocate.
1. Press the power button and the home button together or Power button and Volume button together for a while, long enough till the Android boot mode screen appears. Press home button to reach the options under boot mode. Navigate through the options using volume key and select "Wipe Data Factory Reset"option using shortcut menu button. Again navigate to the option "delete- all user data" and select it using shortcut menu button. (Make sure memory card is not inside; otherwise the data on it will be lost). After the data is deleted, a message saying "Data Wipe Complete" appears. Press the shortcut menu button to reboot the tablet again. Now, your tablet is as fresh as a new tablet
1. The device must be powered OFF to hard reset. Note: If the device is not responsive and does not turn off, remove the battery and re-insert it. 2. Press and hold the Home button and the Power button at the same time. 3. Keep holding Home and Power together for at least 25 seconds, even if the "Startup" screen appears. 4. Release the keys when you see a black screen with a warning sign. 5. Slide the keyboard open. 6. As a shortcut, press ALT+W to factory reset the device. If this does not work, continue with the below steps. 7. Press ALT+L. 8. Press Alt+W for 'wipe data/factory reset'. 9. Press the Home + Back key. Note: You can also remove the battery and re-insert it. Thanks for using fixya
It's Pretty simple just follow below steps:
>Open the SmartThru Application
>click on setting
>Under application you will find the shortcut of Adobe Acrobat
>select that shortcut and press delete key.
Thats it.
Now that irritating pop-up of acrobat has gone forever.
The calculator OS has been upgraded to the version 2.53 MP. For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu. The calculator also asks the user to press either [1:Do NOT show Again] [2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4. Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key. It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions. Once a key is pressed the screen is cleared and you have the solid blinking cursor.
