Question about SMC Computers & Internet
Telnet router - SMC Computers & Internet
Web interface won't responde, but I can connect via Telnet
many routers are not compatible with Firefox or Chrome... have you tried using IE?
Jan 16, 2014 | NetGear FVS124G Router (FVS124GGE)
How do I telnet to linksys E900
Windows XP included a 'telnet' client.
With Windows Vista/7/8, you have to explicitly choose to install the 'telnet' client.
Then, you can use the 'telnet' command.
Dec 14, 2012 | Linksys E900 Wireless Router - IEEE...
Where is the password located at
Hey, the Netopia routers do not have a default username and password. If a password is already set up, you might need to reset the router.
In order to log into the router you need to Telnet into it.
If you are using Windows XP, you can start Telnet from Start>Accessories>Communications>Telnet
if you are using Windows Vista or Windows 7, Telnet is not enabled by default. You need to enable it first. You can quickly re-enable Telnet by following these steps:
Start
Control Panel
Programs And Features
Turn Windows features on or off
Check Telnet Client
Hit OK
After that you can start Telnet via Command Prompt. (or the Start menu)
then once you get into the Telnet Console, type in:
192.168.1.1
and the router interface will open up and let you chanfge settings.
[CLICK HERE] for the official Guide by Netopia.
Sep 23, 2011 | Netopia (3347NWG-ENT) Router (3347NWGENT)
How do I telnet from one computer to another computer, where first computer is connected through wireless and second computer is connected through ethernet cable to "2 wire 2701hg-b gateaway"? Thank you...
Make sure that the computer that you want to telnet to is running the telnet service, and that the firewall on that PC (if using XP/Vista/Win7 and it is switched on, or you have a third party software firewall installed) allows connections to the telnet server.
From the other computer you should be able to just run telnet [destination IP address] and press enter (may need to install telnet client on Windows 7)
Hope that helps
Oct 15, 2010 | 2wire HomePortal 1800HG Router...
Can't telent to belkin cable router model f5d9230-4
You are trying to set up the router with the Telnet connection. I think it is a DSL connection.
Are you able to go online when connected to the telnet modem only ?
or do you have user name and password for the ISP.
Click Here for Step by step solution
Oct 28, 2009 | Belkin (F5D5231-4) Router
How to telnet netgear router
Are you trying to set up the router with the Telnet ISP.
first make sure that the computer is able to go online when connected directly to the modem.
Click Here for more info about how to set up router
Oct 25, 2009 | NetGear DG834G Router
Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Jun 23, 2009 | Adtran Total Access 850 Router...
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Not able to telnet to my home router (netgear WGR614V9)
You have to have telnet access enabled for all earlier revisions of wgr614. See : http://www.seattlewireless.net/index.cgi/NetgearWGR614#UnlockingtheTelnetCosole but bear in mind that v9 is not known officially to have a telnet CLI.
Cheers,
Mar 17, 2009 | NetGear Computers & Internet
Troubleshooting
Telnet is an application layer protocol. If you can telnet to the other router, then you do not have any network issues. However, the fact that you can telnet but not ping suggests that icmp messages have been blocked in the configuration of one or both routers. This is a security feature, because attacks can be launched via icmp messages.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Resolution IT Dubai
Resolution IT Dubai
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
