It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer
before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the
Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the
Help files installed on your
iPAQ Pocket PC. From the
Start menu, tap
Help >
Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device.
Figure 1: Expansion slot
To make your Pocket PC a WLAN device, you need:
To purchase a WLAN CF or SDIO expansion card
To have access to a wireless network
Camera refuses to load cf card. Button that was pushed to eject has no tension after ejecting card for download.\r\nThank you for your assistance
i took the card out of the camera and when i tried to reinsert it it balked about 3/8 " from accepting the card. it is being put in the right way.
I'm sorry, I still don't understand. Does the card not fit into your camera? When you put the card into your camera does it not recognize it?
Could you give more details?
