SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
SOURCE: need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
SOURCE: Philips universal remote needs code for Curtis
Try these
Curtis Mathes
0047 0466
0016 0054
0060 0093
0145 0030
0154 0451
0166
Please rate my help++++Thanks for using FIXYA
SOURCE: I have a universal remote
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
SOURCE: I have curtis mathis model
i had the same problem but i knew the cause (dog stepped on it ) what i did after looking on-line is simply opened the case of my remote (00052d) with the batteries still in and light on the remote and halfway through "popping" the hold clips down one side, the remote light shut off and it started working properly. i think that a case support strut inside was depressing a pad and that might be your problem hope this helps
