SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
SOURCE: I have an RCA Home Theater System Model Number
Make sure that ALL ur cable r well conected! Sometimes just by moving cables it makes a difference.
SOURCE: RCA Home Theater model RTD315W
SOURCE: RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
