SOURCE: Samsonite Briefcase, fogot the Combination Lock can not open it
There is no quick fix, it wouldn't be very secure if there was.
There are 999 possible combinations remaining and if you start at 001 you'd be extremely unlucky to need to go through all of them. Try 999 straight away though, sometimes the tumblers can appear to be set to 000 when they're actually at 999.
SOURCE: I need to put a new combination on my briefcase.
When you open the briefcase on the inside to the right of where the combination is in the center there is a metal lever sticking out.
Push this lever to the left and hold it there while you change the combination numbers.
When you let the lever spring back to it's normal position, the numbers set will be the new combination.
