I would be pressure cleaning for about one min and than it would lose pressure. if you can with this it would help save my nerves. thank you.
this means no water pressure coming
to pressure tank it was consumed when use for cleaning, the water pump does not work,check water pump if function,if there over load reset,or had to jumper the connection of pressure switch.
jump the connection of pressure switch,by passing pressure switch if the motor run just jug for 3 seconds,if run you have defefctive pressure switch,replace pressure switch.have a nice day and rate me if your satisfied to my solution,thank's
