Connect windows 8 laptop bluetooth dre beats
I had the same problem earlier and tried to solve it... First make sure you re-install any bluetooth drivers that you had to delete if you upgraded from windows 7... I had to delete mine in order to do the upgrade. If your laptop comes stock with windows 8, search your computer's website for any bluetooth drivers that you should have. Once you have these installed, proceed. *This might work even without the above procedure so try it out* Right click your bluetooth icon and go to add bluetooth device. Then press and hold the on/off button on your beats wireless till the LED starts flashing blue... It should show up on your laptop. When it does, click on it and it should start the pairing process. Once it's done pairing, simply go to your volume icon at the bottom right of your screen next to your clock, right click on it and go to playback devices... In there, you should see your beats wireless headphones as one of the options. Select them and click 'Set Default'. Then go to youtube or your itunes and play away :)
