Question about Husqvarna Sewing Machines
Husquvarna tension disc diamond deluxe how do i know if their loose
Posted by Mark Mundle on
MissFixIt828
    New Friend:
  • 70 Answers
When the machine is threaded, raise the presser foot. The tension disks will release when the presser foot is up. If the thread is hard to pull with the pressed foot down it should be working. If not, there might be lint or something caught between the tension disks.
Posted on Nov 06, 2013
This is for my diamond r9oyalev- by husquvarna
What do you need? Question is unclear...
Jun 27, 2016 | Sewing Machines
How do I add a hoop size to my designer diamond deluxe? I added it to the 5D.
The hoop size will automatically appear on your Designer Diamond Deluxe for selection as the embroidery arm is attached and the design is chosen.
If the correct hoop size is not appearing at this time, your machine may require updating to include this new hoop size.
Oct 12, 2014 | Sewing Machines
Tension releases randomly on viking designer diamond
Check for loose threads in tension disks. If none, tension disks will probably need to be replaced. This part has a 5 year warranty if you are the original purchaser and purchased from an authorized husqvarna viking dealer.
Apr 04, 2014 | Husqvarna Sewing Machines
How to open tension discs, bernina
The shop may have misadjusted or damaged something during the major servicing. Give them an opportunity to make it right.
Jul 13, 2017 | Sewing Machines
Sewing machine top tension discs very loose
repairing it yourself, without any training or mechanical skills could be problematic, given that you have already rejected 'new part' as a solution.
Mar 08, 2018 | Singer 2250 Tradition
Husquvarna sewing machine Lower thread too loose
try adjusting the top thread tension one number higher till the
stitch looks normal
Mar 04, 2013 | Husqvarna Sewing Machines
I have a Pfaff 7550 that has tension problems. The bobbin doesn't seem to be coming through and the top thread is all loose and loopy. I have tried everything I know and still it is not fixed....h
How are you threading the machine? Is it with the foot in the up position? If you "floss" your upper tension discs with some sturdy fairly rough fabrick like linen. The disc sometimes get clogged up with lint, thread, wax from the tread... and prevent them from providing proper tension.
good luck.
Oct 01, 2012 | Sewing Machines
Tension discs/ shredding needle thread
Your knee pad raises the presser foot and in turn releases the disc tension. The mechanism for this is in the front of the machine. If you can remove a nose piece this will be a lot easier to see,
There is a pin that pushes the tension discs open and quite often this has been removed or adjusted so a to not release tension when the presser foot is raised {more likely if this was a production machine} If someone took the tension control apart to accomplish this that my guess as to question 2.
The best part about Consew is the parts are common and the whole tension assembly isn't expensive. You can find service manuals on their website (see link) http://www.consew.com/Files/112347/InstructionManuals/206RB-5.pdf
Apr 12, 2017 | Consew 206RB
Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
Nov 23, 2008 | Husqvarna Designer I
Tension disc assembly - sewing machine
Sorry but there is no way to explain how to re-assemble the tension mech on here, you need to be actually shown or have someone do it for you. It is very fiddly and needs to be exact, can I suggest you get in touch with a sewing machine tech who(at cost) will sort you out.
Sorry I cannot be of any further help.
Rob
Mar 24, 2008 | Sewing Machines
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
