Sharp 5316 how to enable or disable copy quantity limit
san3409jl
    Habit-Forming:
  • 190 Answers
Adjust user mode setting.
Posted on Dec 25, 2013
3 Related Answers
Anonymous
SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
Posted on Dec 03, 2007
Rick Kasper
  • 2072 Answers
SOURCE: Error code 4H
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Apr 15, 2008
Anonymous
  • 115 Answers
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
Posted on Nov 22, 2008
How to reset user pasward
Good am Mr. Hamzatraders.
Touch the "Enable/Disable Settings" key.
Select "Change Administrator Password."
Enter the current password.
Enter and confirm the new password, which must be between 5 and 32 characters.
I hope it helps.
Jun 13, 2016 | Sharp Ar-5316 Ar-5320 Service Manual
Dear All We want to but sharp Machine but we ...
5316 ,16 copy per minute
5320 , 20 copy per minute
May 20, 2010 | Sharp AR-5320 Black and White Copier
My sharp copier ar 5316 has printed 0nly les than 1600 pages and now showing toner cartridge low, even les than 10%
please check the devoloper , if the quantity is lessthan the specified the same quantity will be filled with toner.
Oct 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
I changed the toner catrige but machine is not functioning.
Is there any alpha numeric display on the quantity display LED such as F2 with flashing 04 or any other trouble display?
I will get back to you as soon as you can give this information.
Jul 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to enter maitenance code
Press # INTERUPT C INTERUPT, THE DISPLAY PANEL GOES OFF EXCEPT THE COPY QUANTITY DISPLAY. Enter the main code and press START
Jun 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier AL1655CS will not let us copy until a new drum is installed. There is a code to get it going anyway. It limits you to a set number of copies even if it is working fine.
c photo c photo then prss 24 machine copy quantity key up and down arrow key then press print key press 7 press print key then solve your problem no show any code print fine thanks
Apr 13, 2009 | Sharp SHP AL1655CS Printer, Scanner,...
My sharp AR 5316 is blicking h and then 2 please wat do i do...and pls how many copy can i make wit it in a day
An error code of H2 om a sharp 5316 indicates an open thermistor.A thermistor is a small electronic device that regulates temperature.You will need to call a copier technician.An Ar5316 operates at 16 copies per minute.Good Luck!
Apr 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 E Problem
Make sure that the side door is secured. There is a corona wire in a brakced on the door and if it does touch the rest of the machine correctly, blank pages will spit out.
Aug 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Open Questions:
14 people viewed this question
Marvin
Marvin
