SOURCE: i have a amana aocs3040ss oven and the door does
If it is a drop down door, then you will probably have to replace the oven door hinges, as the springs are most likely weak.
Hope this helps with your prob.
SOURCE: Have an AMANA AOGD2750 oven blew electronic board
Hi As always when working on anything electrical unplug it or turn off main power ,you will need to open his unit up where you say you saw the smoke, the board maybe toasted, if you are good with electrical you maybe able to just replace one small part on the board, it will have burn marks on it i am sure of that , also the board has Part numbers on it if you want me to locate you one much cheeper then you can get it ,,, ( the heat zink almost always burns out first before getting to the rest of the board )
