Question about Refrigerators
Hi I have a problem with my American style Daewoo
Hi I have a problem with my American style Daewoo fridge freezer. The freezer section seems to not be freezing as well as it should. There is a small build up of ice on the back of unit but otherwise all seems ok. Any ideas much appreciated. Thanks Martin
Posted by Martin Ledlie on
Herbert Metz
  • 102 Answers
It sound like the door seal is damaged or the door itself might be loose.
Posted on Nov 04, 2013
Testimonial: "Hi - all the seals seem fine and the doors close ok. Any other ideas?"
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
Maytag317
Victor
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Anonymous
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Anonymous
SOURCE: ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Posted on Feb 24, 2010
Refrigerator section is freezing food
raise the thermostat setting to 4
replace the faulty thermostat
Nov 09, 2017 | Daewoo Refrigerators
My Daewoo side by side refrigerator ice tray is not spinning over to release the ice how can this be remided
First thing I would do is to try a reset. Here's a YouTube video showing how to do this: Daewoo How to Reset the Ice Maker American Style Fridge Freezer
and here's a generic "how to" guide on troubleshooting and repairing most types of refrigerator ice makers.
Ice Maker Troubleshooting Guide
Aug 12, 2016 | Daewoo Refrigerators
Bosch FD8709 Fridge Freezer (American Style) Freezer section not cooling (Ice maker has stopped making cubes and food starting to thaw) Fridge section seems to be working OK..! In Manual says that the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Bosch Freezers
Ice cube maker on daewoo american fridge freezer
Jul 19, 2009 | Daewoo Refrigerators
I've just got a daewoo fridge freezer the american style and i cant seem to open the doors is there any chance you could tell me if there is a lock on the doors
just keep tugging on the doors, if warm air gets inside the doors the seals stick shut. this happened to ours and it also happens to the chest freezer in the kitchen i work in lol
Jun 17, 2008 | Daewoo Refrigerators
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
