SOURCE: Dvd player not working on 06 Honda Odyssey
The Honda dealer just wanted to replace my entertainment center without even troubleshooting and I wasn't convinced that it was "broken" so I found the FIXYA website and saw that others had the same problem and I followed their instructions and it now works fine. I am going to call the Honda dealer to complain because they should have known this.
We simply pulled the fuse out and put it back in and then reset the radio code!
SOURCE: dvd on honda odyssey
I believe this should be undet the hood, inside the secondary under-hood fuse box (the smaller of the two, located on the driver's side).
If I am not mistaken, you are looking for fuse position #5, which is marked as "Premium" and it is rated for 20 Amps.
SOURCE: honda odyssey dvd player wont eject says loading
clean with air from can of computer type cleaner
SOURCE: Honda Odyssey 2006 DVD player says loading, disk in light on, and
pulled the fuse and left it out for over an hour. The system reset itself when turn back on.
SOURCE: dvd player not working in honda odyssey
a cd player in a car takes some hammering(use wise)so when they go wrong replace it(cost of repair more than unit cost....)easy to remove/replace.
