SOURCE: Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
SOURCE: RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
SOURCE: RCA P52929
go to the menu select the screen option 3 and then select option 6 . adjust projection tv. green is for green use it first then adjust the red and blue until the patterns on the tv screeen appear white.
SOURCE: Realistic Lamp Cost ??
139.00 seems reasonable for a replacement lamp. is that the only problem that you are having or are you hearing a squealing sound and then the tv cycles off?
Dan
SOURCE: whining noise on start up, lamp and TV shutting down
The TV tech isnt too familliar with RCA TVs. The color wheel is the most likely problem no where near 1000. Depending on the model number of your set you can get replacement color wheels at the following link.
http://servicemanuals.vstore.ca/
