SOURCE: i have similar problem..o get restriction code for 2610 nokia
please let me have the restriction code for at&t go phone 2610
SOURCE: forgot security code nokia 2610
Hello thanks for using Fixya
Default security code of Nokia which is 12345 or 00000.
Hope it works if you have not changed your security code
If you have changed then try your Nokia Master code. Type *#06# at the mobile screen to know IMEI no of your mobile Then Go Here.
Give your IMEI no there and calculate your master code and try it.
It will work as your security code If it doesn't work too then you can get online paid security code for your cell. If you want to then you can Go Here.
After getting your Cell info and charges, they will send you code
If you don't want to get it by paying online then best option to renew the software of cell. Just contact to Nokia service provider, Your problem will be solved
I hope this solution will helpful for you Your Rating As Four Thumbs which are given below to this solution will appreciate me
SOURCE: Molim vas da mi pomognete
kako da otkljucam nokia 2130c XpressMusic koji je bio pod sifrom kad se otkljucava i nakon nekoliko pokusaja da se otkljucaa sa drugim siframa izbrisao je onu prvu i sad nmg da ga otkljucam... :/
pomoziteee...
Unapred hvala! :)
SOURCE: CODE RESTRICTION NOKIA 2610 TYPE :RH-86
Restriction code is nothing but the unlocking code for your mobile.
Unlocking your phone just removes the SIM card restriction so that you can use other network's SIM card.
To get the restriction code for your Nokia 2610 model mobile, just visit this site Mobile-unlocker.com ,In this site just give your IMEI number , country & network lock after that within a short period you can get the restriction code for your nokia mobile............I hope this is helpful for you.......
