There is no (consumer) known way for you to do this on your own. Pay the 25 bucks and send it in so they can do it. They have these things locked down pretty tight; nobody to my knowledge has found a way to circumvent it.
my source of research is http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/deinstitutionalize-or-factory-restore/td-p/301697/page/2
SOURCE: my sandisk mp3 player screen broke how can i get it fixed??? please help me!!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: SANDISK MP3 PLAYER
Unplug the sansa and turn it off. Then plug it back into your computer. If it still doesn't recognize it, unplug it and change the usb setting, make sure you highlight it and then press the inner circle or it might change back into the other setting. This worked for me.
SOURCE: instruction manual for sandisk sansa c250 mp3 player
get it here
hope it helps!if the link fails please let me know
SOURCE: need a manual for mp3 player--sandisk c250
Manual for Sansa c200 series:
http://mp3support.sandisk.com/downloads/um/c200-ug-eng.pdf
