The pilot will only turn on for a couple of seconds while the gas comes out to create the flame for the heat to do its job. The pilot is a ceramic fuse that will not stay on at all times. It will click as a sign that is activating (you should see a red glowing light) and ready for the gas/ propane to come out ( the flame will stay on approx. two to five minutes), then it will turn off . Repeating itself many times throughout the cycle. It this is not happening you might need to replace the fuse. Good luck
SOURCE: kenmore gas dryer
That model does not have a pilot light. It has an electronic ignitor. If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken. Probably the igniter is burned out. It is item number 3018 at RepairClinic.com.
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
SOURCE: Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
SOURCE: Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
SOURCE: is there a pilot light on amana gas dryer model LG4309W
There is no standing pilot light. The gas is ignited by a hot surface device that is electrically controlled. Trace the exhaust venting to locate the burner area.
