Lands Phones Logo
Posted on Apr 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the answer machine for a 3410 Binatone speak easey com
Message has been recorded but the machine is not recording messages left and we are unble to access them, we have no manual, very frustrating
Anonymous
Level 2:
Sniper:
  • Expert 54 Answers
  • Posted on Apr 30, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
54
Questions
Helped
35910
Points
396
Here's you manual:
http://www.binatoneonline.com/manual.aspx
Click icon under download....then save..remember where it saves it. Usually when the machine will not record messages there are only a few things that can be wrong....check the Telephone Answering Machine(TAM) section.
You might need to erase all the data and/or change to the correct mode for the phone to function properly. Obviously having the manual will help! :-)
  • Anonymous Apr 30, 2009
    Btw...when you click that link you will need to enter the Make and Model information. Bypass this info if you know how to navigate the page...if not,
    Click the arrow to the right of the window and place DECT cordless phones inside...press select.
    Then select Model: Speakeasy 3410 Combo...press select
    The follow from the beginning of the top message.
Binatone cordless phone twin Model 1120 with answer machine.
Turn on the answer function on by pressing the "Answer on/off" button? Record an out going msg? Read the user manual?
1helpful
Binatone problems i have binatone easy speak 3410 and green light keeps flashing i have deleted all messages but still flashing how do i turn off please help
I believe that is "New Call Indicator". Review caller ID record or
delete all Caller ID records
Repeat the steps above to review the CID list.
Press the MENU/OK/MUTE button, to see ADD to PB?
Press the DOWN button twice to see DELETE ALL?
Press MENU/OK/MUTE button twice, you will hear the completion tone
and the display will show EMPTY.
How do i record my own message
Recording Outgoing Messages:
1. Hold the ANNC-DAYand speak clearly into the microphone.
2. Release the ANNC-DAY when you finish. Your answering machine beeps and automatically plays back your recorded message.
Message limit:
60 seconds
To re-activate pre-recorded message:
Press "delete" during while playing your outgoing message. The pre-recorded message is now activated.
2helpful
How to record Outgoing Message on Answer machine of BINATONE FUSION 2210 DECT phone? Thanks
hi,
if you want to record outgoing message on Answer of BINATONE FUSION 2210 DECT phone, his the step you will follow.
to turn A/M on press R then 5.
to turn A/M off press R then 6.
if you want to record Outgoing Message, press R then 1.
After beep record your message.
Press 0 when you have finished your message, then C to return to standby mode.
To listen to incoming messages, press R then 8.
New messages are then played back.
Press 4 to delete message.
thanks for using fixya
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
When the unit answers a call, callers
are greeted by a greeting message. You
can record your own greeting message
or use a prerecorded greeting
message.
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a
prerecorded greeting message for
callers and ask them to leave
messages.
Binatone e920 quad phone with answer phone - can't record ogm.
Have had the same issue with a single handset. Finally located our manual:
1. Press and hold MEMO (FAST FORWARD) button until you hear a beep.
2. Record your memo, speaking from approx 15cm away.
3. As soon as you have finished speaking, press ON-OFF/STOP button to stop recording.
Hope this helps :)
I need to programme my answerphone for binatone ma760
Generally, Answering manchine have serveral function. Like . Record anoucement, record message, playback message, delete message, answer machine on or off, answer machine remote access. Normally , the key laid out is simular too.
The following manual for your reference.
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
4helpful
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
9helpful
3answers
BINATONE CORDLESS PHONE MA 760
you have to press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button scroll to OGM REC. record ya message after the tone then press ok when done. then scroll down the menus again (press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button) scroll to TAM ON, press ok and thats the answering machine.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
