Thomas Lyra Em2600 was not connected with my computer. when USB cable insert into computer, divice show (Usb Connected Press and hold> to charge bettary) but after pressing > button device not connect/charge battery.
Plz help me.
Thanks.
Arslan
SOURCE: Thomson Lyra pdp2842 Usb Problem
[email protected] contact the vendor with this e-mail address. They can advise further.
SOURCE: Neeed help
Try a format, Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
SOURCE: Not Charging
Make sure the lock is not engaged first.
I would go ahead and do the firmware upgrade for your exact model #:
http://support.rcaaudiovideo.com/downloads.aspx?product=187
If the PC won't recognize the device,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
