Question about Konica Minolta Office Equipment & Supplies
I bought a Minolta CSPRO EP 2080 secondhand and after the first print it gives a error code COF30. Waht is wrong and how can I fix it?
Posted by Tinus van der Merwe on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Replace the developer and drum if you can find them and run the F5 and F8
Posted on Apr 03, 2020
5 Related Answers
godwin paul
  • 3 Answers
SOURCE: c0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Posted on Jun 16, 2008
eurotrans
SOURCE: ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Posted on Jun 17, 2008
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: minolta ep5000 cspro
What you need to do is to take the new toner out bottle out and close the front door and let the copier come to ready again and then try to reinstall the toner bottle again and run the copier... Basicly, the toner bottle was put in wrong and you have to let the hopper go back to home postion and then reistall the toner bottle
Posted on Dec 05, 2008
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Posted on Jan 24, 2009
goodgold
Sergey Artuganov
  • 389 Answers
SOURCE: MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Posted on Oct 10, 2009
Access code needed
Access to what service mode or admin mode, pin#
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 29, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Please I want the solution of the code error C0F22 for the minolta EP 3010 CSPRO
Check the drum density sensor must remove the drum to clean it.
Jun 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
How do i install my CSPRO 4000 printer to my computer?
The EP4000 is a Minolta analog copier. it has no computer connection.
Jul 02, 2009 | Minolta EP1083 CS/PRO Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
73 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
