Try this ::
1. Create a link between your Motorola RAZR Phone and any
Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
