Question about Juicers
How to open ronson vita juicer - Juicers
Hi I was just using my Kenwood vita pro active JE810 juicer and putting through a small apple and it stopped working. I have changed the 13a fuse but it has made no difference. Any suggestions?
It is easier to solve the problem than it sounds. The solution is underneath of the machine located reset button called 'power overload'. Press it and here we have Vita working again. Have a nice glass of juice!
Alvydas
May 11, 2011 | Kenwood Juicers
Jack lalannes juciers and no instructions came with it
Go to this webpage: http://www.powerjuicer.com/power-juicer-manuals.php
Click on the picture of your Power Juicer. Your manual will open up.
Sorry someone has not responded sooner.
Jun 11, 2010 | Jack Lalanne Power Juicer 250 Watts
Open to clean juicer maching
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Jack Lalanne's Power Juicer Manuals of all models which include troubleshooting guide, user instructions, cleaning and opening machine.
Jul 13, 2009 | Jack Lalanne Power Juicer (Stainless...
No user manual for breville bje510xl juicer.
Email me at [email protected] and I'll email you the PDF in the morning Oz time :)
Apr 26, 2009 | Breville BJE510 900 Watts Juicer
Jack Lalanne Power Juicer model cl-03AP
Hi - You can download the manual from the link underlined in blue below:
Power Juicer
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 19, 2008 | Jack Lalanne Power Juicer 250 Watts
I tried to contact the manufacturer
This Juicer pulls apart with a 1/4 turn counter clockwise. I've had one for about an hour ;)
Mar 25, 2008 | Juicers
Cleaning my juicer
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls. Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Mar 23, 2008 | Juicers
How to dismantle my juicer?
Simply turn the top counter clockwise like you would open a jar.
Aug 10, 2007 | Acme 5001 Supreme Juicerator Juice...
Juicers Logo
152 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
