Yamaha HTR-6130 Receiver Logo
Question about Yamaha HTR-6130 Receiver
I'm trying to hook up my Acer Aspire x1700 to a Yamaha HTR - 6130 AV Receiver using the Optical digital audio cable plug. Not getting any sound, not sure what source to set on the receiver.. talks about decoding... not sure what that means.. Please help! I have been at this for hours.
Posted by unknowndesti on
  • Anonymous May 11, 2010
    Do you have your computer plugged into the CD or the DTV/CBL connection?
Mike LaPres
  • 757 Answers
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
Posted on May 08, 2009
I have hooked up my DTV box via HDMI to my Yamaha. I have hooked up my Xbox via HDMI to my Yamaha. I have Hooked up my Yamaha via HDMI to my Toshiba flat screen. I can get video from all but I am not...
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
1helpful
No sound on DVR HDMI port, but does work on other HDMI port
Not all HDMI ports support Audio or they do but only one way Audio out or Audio In. If you have an optical connection you can try that.
1helpful
3answers
1helpful
I have a similar problem with my ACER X1700. I am using HDMI cable to connect to TV and getting audio there, but unable using analog cables to get audio to receiver. Do I need the ooptical cable?
No, you don't have to use an optical cable, although it would sound considerably better. If you go into the "Menu" of the receiver and toggle to "Audio input Mode" select "Auto" and that will do the trick. If not, post a comment and I can guide you some more. Hope this helps
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
1helpful
2answers
Yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
1helpful
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
3helpful
4answers
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
3answers
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
