Question about Child Craft Contemporary Dropside Crib 10171
Is crib safe? Mode # 47167-0444 - Child Craft Contemporary Dropside Crib 10171
Generation next crib cut 8-99 recall?
Try it out with a toy doll first make sure it supports the weight of the doll then put a brick in
Mar 09, 2014 | Babys Dream Generation Next Crib
Need part to immobilize simmons drop side crib 6808 97 139
This crib was not recalled so there will be no kit available to immobilize the sides. You can verify the recalls at www.cpsc.gov. The cribs with the metal rods are still safe to use. The cribs that were recalled had plastic hardware on the drop sides.
I hope this information is helpful.
Dec 04, 2012 | Simmons Mattress Baby Gear
We've lost our metal/spring matress support that hangs off the hooks on the head/foot boards (very decorative heirloom style). can we find a new or used replacement anywhere. we have a grandson on the...
Be very careful with "Decorative heirloom" style cribs. The CPSC (Consumer Product Safety Commision)
at www.cpsc.gov warns that older cribs may be dangerous and not up to current safety standards.
If you look hard enough at flea markets and 2nd hand stores you may find the mattress support but
your crib may put your grandchild's life in danger. It is just not worth it when you can buy a new crib for about $100. If you can fit a soda can thru the slats on a crib, it is dangerous. You only get one life, one child's life and it isnt worth risking. Be safe and I hope you find a safe conclusion.
Mar 11, 2011 | Baby Gear
I bought my 6 month old baby boy a crib at little angels network consignment sale last year . later to find out on my own,that this bed is not safe,so i research to see if there was a recall on this...
My 2 1/2 year old was in a Delta Crib that turned out to be Recalled and it was only because of the Drop Down side - they said there were no issues with her Crib itself but with all of the Issues they had had last year they are being safer and not sorry - On the board under the mattress I found the model # and I called Delta (Got their # off of DeltaEnterprises.com) and they sent me two peices to install to keep the drop down side from going down - and that fixed any issue it had - and it is a safe crib still. Call them do not tell them you got it second hand - and give them the Model # and they should send you a "fix Kit" for the problem. Free of charge.
Jan 16, 2011 | Delta Luv Delta - Baby Products 5-in-1...
Cant put the crib togther
First you will need all of the original hardware that came with the crib for it to be safe. Then you might want to google it to make sure there were not any recalls on it ever, just to be safe again.
Then I beleive you will need 2 flat screwdrivers and an adjustable wrench or plyers. You will need to connect all four sides and the bars that go under the sides that release the side to go down. Then the parts that hold the mattress and then the mattress.
ETRONIC
Mar 15, 2010 | Bassett Mission Crib
IBOUGHT A JENNY LIND CRIB IN 1980. IS IT SAFE TO
sure, just do a good inspection, check for any looses screws or cracked pieces, repair if req. check for mold also if it was in damp storage, specially the mattress.
Jul 22, 2009 | Evenflo Jenny Lind Crib
I have a status crib which went bankrupt last year and need to find the bottom that holds the mattress.
I lost my bottom during a move. I fixed it by using a "wood" crib board (that holds the matress) and removing the J hooks, replacing it with strong chain about 6 inches long in place of all 4 J hooks, then using the original bolts, putting it through the end loop of the chain, into the crib to hold it firmly and safely in place. It's working safely and perfectly.
Jun 09, 2009 | Baby Gear
Child Craft Contemporary Dropside Crib 10171 Logo
Top Child Craft Baby Gear Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a Child Craft Baby Gear Expert? Answer questions, earn points and help others
