SOURCE: remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
SOURCE: my viper alarm remote just beeps flashes TX and
Try to reprogram this. If this routine does not work please let me know and we will try something else
SOURCE: Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
SOURCE: would like to know what the bottom 2 buttons mean on Viper 7153v
the bottom button is for function shift, and is used (with aux button) to activate certain functions (add on optional features like trunk pop, window roll up/down, rear defroster, etc--all depend on car and install) or by itself for status updates (interior temp check-press once, release, press and hold; remaining runtime-press and release three times, press and hold; lock status-press and release twice, press and hold). it is also used with lock and unlock for silent arm/disarm, and also to enter valet mode.
