Sub Zero 642. Getting a fairly loud humming sound above the freezer. Almost sounds like a fan hitting something but had it a part to day and that is not the issue. I know there are compressors above the unit and wonder if this vibration sound is the beginning of the end for one of the compressors.
If it is a compressor issue, is it realistic to fix one of these yourself? Is it just swapping out parts??
Check your evaporator and, condenser fans and, lube them with machine oil one of the back ones is stuck
I would never get rid of my Sub Zero they are the best made and, I service all makes of refrigerators good for you; buying the best!
Posted on Apr 30, 2009
If the fan is good. then the compressor is going bad. It is not something you can replace yourself, due to freon and also the system needs to be charged properly or it would not be worth the money to repair it. You have to be certified with your EPA lic. to be able to buy a compressor or freon legally anyways. I would recommend calling a tech out and let them talk to you about replacing the compressor
Dec 01, 2013 | Sub-Zero 642
Apr 15, 2017 | Sub-Zero 642
Mar 26, 2012 | Sub-Zero 642
Aug 10, 2011 | Sub-Zero 642
Jul 04, 2011 | Sub-Zero 632 / S
Apr 29, 2010 | Sub-Zero 642
Dec 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Jun 21, 2009 | Sub-Zero 700TR
May 10, 2009 | Sub-Zero 642
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Jun 30, 2014 | Sub-Zero 642
290 people viewed this question
